2007 ExMark Model LXS35DV725 Year 2007 35 Hp 72" deck
bondo11
I am having a problem with one drive wheel not engaging ?
You start it up warm it up and your ok for a little while, then it stops working, only one wheel turns !
I checked the hydraulic oil, it was down a little bit, so I topped it off .
Same thing again after sitting for a half hour or so it would start working then stop again ?
I plan on checking out the linkage tomorrow weather permitting !
Why would one wheel work fine and the other not ?
Thank you in advance for the reply !
bondo 11:confused2:
