Need help in replacing drive belt.I removed the deck and the belt that goes with it.
To remove the drive belt manual says to put a 3/8" socket into square hole that is attached to
bracket that has a pulley on it. Use the rachet wrench to force back pulley so you can remove
the drive belt. Here is where the problem is. There is no way to get a rachet wrench in the
square because things are in the way of getting there. Also only about 3/4 of the square hole is visable
Please advise me on this matter.
Thank you
Shadowcat
Thank you
Shadowcat
