2005 JD 737 ZTRAK Mower
Rman
Hello, I did a search first to see if there was a thread already for this machine,answer was no so here goes:) We have a ztrak with a kawasaki engine FH680D-23hp. I want to buy a supply of good oil filters.The one in it now is from the dealer AM107423. It says in manual 10w30 which I have used valvoline in the past. Any recommendations as far as filter brands,oil, or blade manufacturers/retailers would be appreciated! thank you!
car quest sells filters to fit that motor. I have bought in the past a case of filters for a 19 hp kaw and they worked great. I now have a newer john deere still under warranty so I use original jd filters until warranty is up. car quest is about half price if I recall correctly. What part of Michigan are you in?:thumbsup:
