Export thread
2004 Troy Bilt super bronco 42" automatic
#1
W
wallychoppers
When i put my mower in foward it jerks and grinds/clicks. Works fine in reverse but not foward. The linkage is engaging the drive belt and the variable speed pully engages the trans belt but will not move. I have taken rearend/trans apart but did not see anything visuialy wrong with it. Anybody have any suggestions?
Thanks
Wallychoppers
#2
CajunCub
CajunCub
You opened the transaxle and saw nothing wrong? Look at the axle splines?....Good Luck!
#3
W
wallychoppers
turns out the shifter linkage needed to be adjusted, it was allowing it jump out of gear. works great now.
