Hey all. Was working a lawn today and the strangest thing happened. The metro is just dying anytime you try and engage the blade or shift into a gear. Was working fine, so I can't explain it. I found a small hitch clip on the ground where I was working....could be coincidence, but maybe a rod fell out somewhere? It's definitely electrical/safety related because its instant when the engagement lever is pulled and lets go of the safety underneath. Starting to look through the exmark manuals now, but wanted to see if this was a common/well known issue. There's very little that seems to make these things go....I have to believe it's something stupid/easy.
hitch clip I found....only it was circular, and it didnt have the safety wire.
