I'm looking at this machine and would like some input.
I'm having issues with my back and currently have a Scag STHM which is not very comfortable.
So I've started to look at ZTR's. I found this machine which was made in 2004 & has a Kawasaki FH680V with 1111 hours on it.
How is the quality of the cut?
The asking price is $2000 or best offer with no physical damage and normal weathering.
I don't know anything about what you are looking at but I do know I'm thinking about going back to lawn tractor because my RZ4623 rides so rough, I have a lot of low back problems, I've tried lowering air pressure in tires and it helped some.
My father Inlaw bought a YTH2246 in 2013 same year I got my Z-Turn, I mow his lawn every now and then with his tractor and it is much smoother riding than my Z-Turn.
Commercial Z-Turns probably ride smoother than my residential model.
You might want to try a few different ones before you decide, if your lawn is very rough you might not want a zero turn, especially if your back is getting worse.
