- May 6, 2010
- 12,060
You definitely don't know Kohler engines. The Kohler command has always used hydraulic lifters and the same style lifters used on auto engines to this day. And they were not used on lower end mowers. The Command is considered the flagship engine and they were used on lower end mowers because that was the only engine that Kohler offered. The K-series and the magnum series were being phased out. The Courage series was Kohlers first attempt at consumer grade engines. Up until that time Kohler engines were not really designed for the consumer market.Research seems to indicate these CV models used hydraulic lifters and are self adjusting. Having changed oil and filters regularly and leaving the valves alone for 26 years may be why they still work.
On the issue of adjustment, maybe “If it ain’t broke, don’t fix it” applies here.
Apparently the hydraulic lifters are for lower rpm engines on cheaper mowers (likely used where little or no maintenance by low tech users is expected.)
This engine starts easily, runs fine, and does nothing stupid.
Various forum thread attempts to service hydraulic lifters seems to induce more problems than ever solved, usually ending in arguments over how to do it.
All the other to do’s are noted especially cleaning.
(No clue what a JD or SAM box is.)
(Item #11 in Post 3 not applicable in WUMC suburbia.)
As much as asking AI irritates, perhaps it is simpler. And seems to not tell the asker, “You are a dumb butt” for asking.
JD means John Deere and SAM is Spark advance module, Which was the first 2 advances in spark advance ignition. You had the ASAM which was analog and the DSAM which was Digitial spark advancement. I have never seen a SAM on a CV15. The SAM was used on the CV16. And the Command CV15.5 was actually a lie told by Craftsman that started the HP lawsuit.
Sears mower says 15.5 but from your previous post the engine clearly is marked CV15 which Kohler rated at 15 not 15.5. Sears would use a different enigne rating system than other companies so they could use a different HP rating on their mowers than what the engine manufacture used to rate their engines.
