TxFig
- Apr 18, 2012
- 2
- 11
About a month ago I was helping a friend clean out the home of his uncle, who had passed away ~4 months earlier. The estate had been settled and everything left in the house was "up for grabs" - including a 2 yo Husqvarna 46" riding mower (20 HP Kohler engine).
The little "hours indicator" shows it has 56 hours of use.
The first thing I did when I got the mower home was to drain the gas tank, change the fuel filter, and pull apart the carb (it was pretty clean). I put a new battery on it (since the one it came with wouldn't hold a charge).
After reassembling it, the mower started up and I mowed the back yard (about an hour). The engine seemed to run fine - but had less power (ALOT less) than the 21HP yard machine I've had for 7 years.
This weekend I went to mow again (texas, grass grows fast). This time it wouldn't start (turns over just fine - just no "fire"). So I pulled off the carb and look at it -- still looks pristine. Put it back on and spray in a bit of starter fluid.
Engine would fire and start with the starter fluid, but die very quickly. After doing this for ~30 minutes, the engine finally caught and would continue running....
very, VERY roughly. It has even less power than before (comes close to stalling when I engage the blade). It sputters constantly while running, and even backfired when I turned the engine off.
I'm stumped. I don't even know what to look for.
