T The Push mower Active Member Joined Aug 22, 2020 Messages 59 Aug 25, 2021 #1 When the engine is cold the throttle controls the engine RPM as normal, but when warmed-up the engine appears to be full throttle and will not idle down with the throttle lever.
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,058 Aug 25, 2021 #2 Heat related air intake leak. Need to check gaskets between the carb, and the engine head.
T The Push mower Active Member Joined Aug 22, 2020 Messages 59 Aug 26, 2021 #3 Thanks...tightened two carb nuts and she is good to go now...other than the pecking engine.
