1998 MTD Yard Man HN 7180
From the diagram that mark posted it looks like the pin in the right side of your picture should fit down though a hole in the clutch on what would be the left side of the picture. So your clutch needs to rotate like 90 degrees clockwise if viewed from the under side and then the pin fits though the hole
Yes looks that way to me too - a picture speaks a thousand words !! Many thanks.
