1998 Dixon ZTR 4515K blade speed bogging down on 42" deck
George4
So I was cutting some grass today and when I was getting toward the end of the yard the blade speed was really getting slowed down while trying to cut some taller grass. The engine was staying at the same rpms, it was just the blades slowing down. I did not hear any belt noise and it does seem to have proper tension. So do you think that the PTO clutch is starting to slip? Is there any adjustment on the electric clutch? Any other ideas? Thanks.
~George
