Export thread
1991 Briggs 28707 12hp flathead running issues
#1
BustedKnuckles
BustedKnuckles
Ladies and Gentlemen,
I bought this engine second hand and it runs good except for seeming to run out of fuel at times while mowing. I've learned that if you choke it for a second and then back to full throttle it runs good for a bit before having to repeat the same process.
I checked the bowl and emulsion tube before installing in on the mower and they were clean then but I haven't checked them again yet. Both the idle/fuel jet screws are 1.5 turns out. The fuel tank has been completely drained and the fuel filter is brand new. I have many carbs on hand but I would rather fix this instead of just swapping out parts. Gas is fresh and was purchased today.
Thanks in advance for any and all help.
#2
BustedKnuckles
BustedKnuckles
Carb swap done and fixed; thanks for the views.
#3
R
Did you mean a 280707? If so this website might help you in the future.
http://dl.dropbox.com/u/12502267/B&S Service Manuals/01_270962SingleCylinderLHead.pdf
#4
BustedKnuckles
BustedKnuckles
Thanks for the help!
#5
BustedKnuckles
BustedKnuckles
After swapping this carb to another engine, it turned out to be trash in the bowl; that'll teach me to be lazy again....
:biggrin:
