1990 Cub 1420
dww128
Got a 1990 model 1420. The need for some repairs turned into a restoration. I have replaced every electronic component and checked connections. The tractor should start. Instead, I get a "depress pedal" light from the dash while the ignition switch is in the "start" position. The pedal is depressed and the pedal switch functions as it should. What am I missing?
