Hi Will This photo is from the front of the tractor looking at the right side of the tractor brake pedal side Thank youIf you're talking about that L-shaped bracket, that is the lift assist spring bracket. A spring hooks into the hole in the bracket and then connects to a hook on the pedal linkage. This makes it easier to lift the deck.
Hi Will alright great thank you for help BillSorry for the delay. The circled area shows where the spring attaches. Lower your deck all the way down, connect the spring, then grab the L-shaped bracket with a pair of pliers and rotate it 90 degrees counterclockwise until the bracket is in the 3 oclock position as in the 2nd pic.
