1980 Lawn Boy
svenskar
I recently revived this puppy after it sat for a couple of seasons. Started on second pull. However, it has kind of a rollercoaster idle. Steady power when I hit thicker grass. I’m guessing a carb issue?
It looks like one that I have. It will have a F100 engine with a plastic carburetor. The carbs are fairly easy to clean if you have any experience with small
engine carbs. Clean it and get rid of the old gas in the tank and it should run fine.
Regards,
Jerry
