I've never had a riding tractor, mower. Can anyone tell me the way to reinstall the mower deck main drive belt? I had to replace the blade belt, as it had snapped. Removed deck, cleaned, lubed, installed new blade belt, reassembled, installed. Problem is, I can not figure how to pull the mower forward in order to line up pins, after I installed the main drive belt.
At first I put the deck in place with all pins etc. Then noticed there was no way I could get the main drive belt on. So I removed the two front pins, pushed deck backward against tires. Installed belt. But now...how to move deck forward and lift to push pins back in??
