19.5 intek Briggs&Stratton
justee
Valves are not moving, engine turns over just fine, not making any strange noises. suspect the cam gear but not sure. any help before I tear into it would be appreciated.
MowLife
I assume you took the cover off to see rockers. Do push rods move at all? Is piston moving?
justee
piston does what it is supposed to do......
justee
No....the pushrods don't move at all.....
Tinkerer200
Assuming the push rods are actually in their cam follower sockets, unlikely both would come out at same time but check, you have a tear down job at hand. Sounds like cam shaft broke, or more likely, cam shaft gear.
Walt Conner
PS: I can send you a PDF of Service Manual IF you like, address below, put in proper format and remind me engine model number and what you want.
wconner5 at frontier dot com
