RustyBucket
- Jul 4, 2020
- 3
- 8
G'mornin!, my 18hp Vanguard regularly strips the nylon starter gear. I've replaced both the starter and the gear NUMEROUS times. The engine is in my '03 EZGO golf cart and it ain't easy to access the starter. The ring gear on the flywheel is aluminum and looks like it is riveted in place. QUESTION: is there way to replace these parts with steel gears? I caused myself all this trouble when I replaced the camshaft, the new cam doesn't have the compression release flyweight. I replaced the battery, cables & solenoid with BIGGER parts & the engine spins fine on the starter but eats the gear after 20-30 starts. The engine model# is 350447 & the type is 1075-A1 5848.
Thanks in advance for your help !!
