I am have an issue with my tractor. It won't turn over. The only way I can actually start the tractor is to take the spark plug out, and then it will start after shooting out some fuel. Once started it runs fine. We have removed and cleaned the carborator, replaced the spark plug, replaced the starter plug and it has a new air filter. Can anyone advise what needs to be replaced? Thank you.
