185 hydro.
albertrsp
Hi,
the 185 hydro with kawasaki fc540v cs00 engine,ran then just wont start.checked all things electrical,switches,etc.
has spark and backfire thru carb,but wont fire up.I am at a loss !
Can someone help
many thanks
albert
I would start by checking the valve clearances to make sure there isn't a valve problem. Also may want to check the flywheel key to make sure it hasn't sheared.
albertrsp
Thanks for reply
I will check valve clearance and flywheel.Its the only things I have not checked.Also.
I did notice that before all this, it ran on after ignition off,and it only stopped when I closed choke butterfly.
many thanks.
Rokon
By "running on" after the ignition is off, is it a dieseling sound or running like normal with the key on (but it is in the off position)?
albertrsp
Hi Rokon,
Sorry about late reply,but we are having a bit of trouble in paradise.It seems the whole worlds gone mad!
Yes,it ran on with key off.However I have subsequently had the coil short out and smoke.I suspect that this may have been the non firing cause?,after weeks of rechecking ,charging battery,etc,etc.
I am trying to source another coil,which will take some time cause its an old deere.
Thanks again and what u think about coil?
albertrsp
mechanic mark
Hi mechanic mark,
Thank you,Its awsome info.I think its the coil,(smoking and hot),have you got one and can u post to Israel?
Thanks and sorry about delayed reply but,we got some troubles in paradise
Posting this in case you need parts listed in future. Searching for coil. Search : eReplacementParts.com
John Deere Model 185 Lawn Tractor Parts
Kawasaki Small Engine Ignition Coil
Error click anyway
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
Trouble everywhere, prayer is the only answer!
