1822 Hyde oil change
Patwarren
Can anyone tell me how to do this ? 1822d and what do you replace it with regular motor oil ? Is it good to change over to synthetic ? Thanks I appreciate your help !!!!! :thumbsup:
if you are talking about the hydraulic fluid, I use Grasshopper hydraulic fluid. It's expensive but that's what the manual calls for. For the engine oil I use diesel oil I get at T.S.C....russ
