I have a 1994 cub cadet with a 18 hp kohler v twin When shutting it down it sounds like you can hear the compression in the motor two or three strokes. Sounds like exhaust compression. It is not a backfire. You can also hear this during it running. Seems to be on the right side of engine when sitting on the mower. To better describe it it sounds like air being released. Any suggestions what to look at. 702 hrs on engine. Heard nothing while mowing, but I had a time when it seemed like it was running out of gas, going downhill, shut it down and checked but it was 3/4 full. Started it again and it ran fine. The engine sounds fine ohter wise and runs smooth.
Thanks
Ray
Thanks
Ray
