ThatMowerGuy
- May 23, 2012
- 2
- 4
This may be a little off subject for lawn mowers but same principle... I recently bought a Lincoln Weldanpower Welder that had a 16 HP Briggs and Stratton Engine on it that is blown up and missing parts... I have a 18 HP B&S that is off of a craftsman garden tractor and it very very close to the same engine besides the crank...:thumbdown:
MY QUESTION IS::: will the 16 HP B&S crank fit in the 18 HP B&S without too many issues???:biggrin:
Both engines are horizontal shaft/crank engines. I have dissasembled both engines and it looks like it will work but the 16 hp has an oil filter and pump built into it and the 18 HP has a oil splasher bolted on the rod cap of one rod...:frown: if i use the crank and rods from the 16 hp and bolt the splasher on the rod cap will it cause the crank and rods to be unbalanced...
Please let me know if there is any extra info needed...
Anybody have any experince doing this???
Thanks!
Mike
Thanks!
Mike
