170 PTO clutch
Ean
We got the 170 going yesterday but it sounded like it had a dry bearing but I think it's the pto I tried to engage it but it wouldn't do anything but the battery is no good would that not make it not engage I'll try io engage it while it's hooked to the battery charger
Ok I started it on the battery charger and engaged the blades it choked down and died started it put it on wide open engaged it and it almost died but didn't let it run for a few minutes cut them off the noise persisted so could someone tell me how to fix it
We took the pto clutch off today and took it apart and greased the bearings and it sounds a lot better
