CRDuncan111
- Oct 22, 2016
- 1
- 2
Toro pours oil out of the top shaft oil seal. Replaced the seal. Same leak.
After removing the blower housing, try moving the flywheel back and forth. Try different positions by rotating the flywheel a little at a time. Sounds like their could be upper bearing damage that is allowing the crankshaft to move around in the seal. Make sure the seal was also installed correctly and not too deep, allowing oil from the passage hole to come out above it.
