16mm blade adapter for electric conversion
gge5
Hi all. I'm new to the forum. I'm an electric hobbyist - I've built my own electric motorcycle, and solar panels from scratch.
My current project is a 20" electric walk-behind lawn mower. The part I'm having trouble with is finding a blade adapter that will fit my Bosch motor.
It has a 16mm (0.63") keyed shaft. All of the adapters for sale say they are a replacement for mower model xxxxxx,, but that doesn't help me much.
Can anyone help me find one that will work?
I realized that the shaft is probably 5/8", not 16mm. I found some 7/8" adapters, but that won't work. Still searching...
Re: 5/8" blade adapter for electric conversion
Finally, armed with (hopefully) the correct shaft size I found an adapter! I'll update this thread with my build photos as it progresses. Sometimes all it takes is for to explain your problem to someone...
217-1277 - Blade Adapter, Murray 20617, 24211, 54211
Edit:
Darn... The adapter is slotted, not keyed :( Getting closer, but no exact match yet.
