Hello,
I have a Cub Cadet 2165 with the B&S 16hp V-Twin engine, about 600 hours on it. Mowing yesterday the low oil light came on and I shut it down as soon as I noticed it, the oil level on the dip stick is okay and the engine starts and runs well. Thinking it might be the sensor, I removed it from the engine and started it to confirm oil pressure, no oil came out of the hole where the sensor was mounted. Now I am concerned the oil pump is not working. When I started the engine without the sensor, it was for a short time at low RPM, does it take time for this engine to develop oil pressure?
If it is the oil pump, any direction on where it is located and how to get to it would be helpful.
Thanks in advance for your help!
