Mower Model = 13AF675G062
Purchased April 2002
Problem = Suddenly started jerking. (Imagine the throttle moved between fast and slow.) Then it started popping when mowing, getting worse up an incline and when turning. The more it was used the worse it got. I only used it 1 cutting after the popping started. This occurs in forward and reverse.
So my first thought was a worn clutch or selector arm. When I took the trans apart the clutch and gears were in ok shape, nothing immediately noticeably wrong. But when I lifted the axle /differential out what looks like pieces to a keeper or some type of spacer fell off. (I have attached pictures.)
These pieces fell off the right side of the differential housing. Is this an indicator of a bad differential? Should I look at something else?
