16 hp v-twin vanguard flywheel removal
pajohn7007
What is the proper way to remove flywheel. Best way to hold flywheel when breaking nut loose.
briggs
best way is to use a an impact gun it will come off easy most times u don't need to hold the fly wheel if u use a gun ...Then i use a puller to remove the flywheel be-careful not to damage the threads on the crank shaft ..And not use a hammer on it
pajohn7007
Thanks, Pajohn7007
