16 hp briggs runs fast
okfine
I could use a little help. I have a 16hp briggs ohv engine. I have adusted valves, rebuilt carb. The engine starts and smokes blue smoke for a little while then quits, however that is not the issue at hand. The engine revs really fast, I move the governer lever toward the front of engine and it slows down but when I let go it speds way up again. I looked on line to how to adjust governor, they say to loosen the bolt at bottom of lever, mine has no such bolt. The engine number is 28u707-1174-e1. Any thought on both issues?
Thanks
