15-38 HXL Toro Wheelhorse with Briggs 15hp engine
jta
Mower will not start normally (clicks when ignition is turned). Mower starts and runs when starter is jumpered but shuts down when pto is engaged. Mower starts and stays running when pto is engaged with reverse mowing key turned. Checked fuses ...they are fine. seat switch seems to be working properly. Any ideas what the problem could be?
Check your battery voltage. Should be about 12.6V before you start.
