PushnFords
- Oct 19, 2019
- 2
I have a 14SB parts mower I'm trying to disassemble but the clutch is different than my others. It is the newer round Warner style. After taking the lower half off my others all have inner threads in the center where you run a forcing bolt into and it pushed against the crank to remove the clutch. On those the center bolt that holds it all together is a long bolt with a wide washer head. This mower has a different style retaining bolt and there are no internal threads. I'll try to add some pictures but I'm a little stumped on how to remove it. Not sure if I stripped something out when I removed the bolt or if it is made like this?
