13 hp mtd blows fuses
BigRich
replaced solenoid,starer,ignition switch,diode, still blows fuse instantly upon turning switch to run without getting to the start position, no visible frayed wires or bad switches....im stumpped!!!
greggn
Probably wrong ignition switch using a battery ign switch for a magneto ignition can cause $$ problems. Even though back of ignition/key switch have the 5 connectors they are in different order.
