Hello, I came by a 2014 Toro Recycler with a 7.25 B&S Engine (128M02-0133-F1) on it that wasn't working. The condition looked pretty good, figured it would be easy to get running. I cleaned the carburetor, replaced spark plug and air filter. Doesn't start still even with some carb cleaner sprayed through spark plug hole. I purchased a compression tester and when I go to pull it over, it only reads <30 psi.
I don't have experience nor do I have many tools, where should I start trying to fix this? Lap the valves?
Do I need a leak-down setup?
Thanks,
Marco
Thanks,
Marco
