125B leaf blower won’t start
dmiller2651
The leaf blower will not fire at all. These are the things I have done.
New carburetor fuel lines and filter
New ignition coil
New spark plug
Have removed kill switch wires from ignition coil and confirmed spark at plug
Cleaned fire arrester screen
Have compression but have not tested for lbs.
dougand3
Try a tsp of fuel in the plug hole. Pull 5-15x. You should get a burp and 2 second run. If yes....fuel delivery issue. If no, compression or timing issue.
