122c Weedeater question
DaVinciB
Just got a new Husqvarna 122c weedeater, which I really like other than the string guard is rather small and flimsy. Is there a better option from another weedeater that would fit, that I can replace the Oem one with? Even If I have to "Make it work" that would be fine, just wondering if anyone else has had this issue and what you have done. Thanks in advance, B
That little 22 cc engine is a gutless wonder and putting on a larger string guard will just cause the engine to be overloaded.
