ericmows125
- Mar 27, 2013
- 2
- 4
Hi everyone!
My Briggs and Stratton has had a popping problem for a while. It starts up fine and runs fine, but it always pops no matter what speed the engine is running at. I have cleaned the air filter, replaced the spark plug, cleaned the carbuerator bowl,replaced the needle valve and sprayed the carb with carb cleaner. I have to have the engine run slightly fast on idle otherwise the engine quits after a few seconds.
