11hp tecumseh linkage
cvb
Hello,,,have a coleman powermate 5500 generator with 11hp tecumseh motor...been scouring the web trying to find some pictures of linkage between carb and governor..even emailed some sellers on craigslist but no luck...believe mine is wrong or bend out of shape ,this is model of motor OH318EA anyone have a few pics of linkage or any website where i can find some?
EngineMan
Tecumseh have so many it would hard to say, post up photo of engine with carb fitted and the links, that way am sure we can work it out for you.
EngineMan
I have put arrows on the photo to help you, you will need to straighten the link rod from the yellow arrow (the loop) to the end (right) the red arrow ie it should be straight from the loop to the end of the rod to carb. there should also be a spring (governor spring) in that loop I believe. you also have the breather tube missing from the valve cover.
There's something just not right with that set up, that I can't figure out. On the loop there should be a spring, but the part diagram doesn't show one. This leads me to believe that it may not be the correct link. Second, on this type of generator there should also be a tensioner to keep it at a constant running speed. This keeps the voltage and hertz consant and prevents burning up whatever is plugged in. Can you post the full model and serial numbers for both the engine and unit.
EngineMan
Like you say, there is something odd...!
OH318EA-222714D parts list is showing a spring.....see below.
cvb
Heres pics of tags on generator and motor,didnt run when i got,located a rebuild kit for bottom of carb starts and runs but not right,will surge and rev way to high i believe for safe runningPicture 010.jpgPicture 011.jpgPicture 013.jpg
EngineMan
I have had a good on my files and over internet, and I can't find any good photos to be able to help you anymore.....sorry.
And I am sure more parts are needed to make it work 100%.
cvb
thank you,greatly appreciate the help...will try craigslist again to see if someone will take pics of the one they are selling..
