it's an 8 year old engine but has been pretty well maintained. Monday of this week it was doing fine...then it started running about half power even with the throttle moved up. Later on it started speeding up then slowing down. Then it just started running wide open no matter where I had the throttle.I can't see any thing hung, for instance the butterfly in the carb. Could it be the govenor is mal-functioning?
