Mower deck 1045w/46"deck problem
jwp1466
I can not keep belt on,comes off as soon as you turn on.Belt,spindles and idler pulley look good. any ideas thanks
You must remove the idler tension pulleys to check them, making sure the bearings are smooth and free. Any doubt, replace. If the belt is more than 4 years old, replace. Triple check, is the belt routed correctly, yes it has happened to all of use. Any rust or dirt on the pulleys will cause the problem.
