muckinfonkey
- Jun 12, 2010
- 3
I am working on a 10hp Tecumseh TVXL. it is in a mower. I get no spark from the coil with the kill wire connected. But, I do get spark with the kill wire removed. This wire connects to a tab on the motor along with another wire from the front (probably switch) I am not sure where my next step should be. Should I have ground to the coil? or is that what "kills" the motor? my battery negative grounds to the frame of the mower. I am just not sure what to check next.....I assume I am having a problem in the wiring that leads to the kill wire. Any help will be great thanks.
