Export thread
02 928D grasshopper verses 08 928d Grasshopper Fuel Consumpition
#1
1mstrb
ok here Is the Question for any of you My older 928D 2002 uses about 3/4 gallon per Hour and the 2008 uses about 1.5 gallon per hour .
Is there a reason that my older mower gets better per hour ? I cut very large properties I'm on a mower 4 hours at a shot .Both mowers doing the same property I just don't figure that out and Yes my machines are serviced every 200 hours fuel and oil filers replaced Rotella 15/40 oil . What is Wild is that the 02 has a 72 inch deck and the 08 has a 61 inch deck Any Thoughts Out there??
#2
R
Rd05lly
Emissions
https://www.dieselnet.com/standards/us/nonroad.php
#3
G
ghuns
Yup. Same reason a early 90s VW diesel gets 50 MPG and a new one barely touches 40.
