Kohler KT726 oil filter, full size option?
iowaztr
As in my previous about changing the oil filter mess, I am planning on changing the oil in my Toro Titan with the Kohler engine.
Looks like I should have room to replace the short filter (Kohler #12-050-1) with a full size/longer filter. Any reason not to? Filter numbers that would work?
Kohler 12-050-2 should be the longer one. If there is room to install it, I would say use it.
A warning about the appearance of the canister size is not to assume that it has more or better filtering media than the shorter version.
Aftermarket filters are bad about using long canisters, but they have short filter media. They are selling the illusion that you are getting a better product. It's a shady money game that is often played.
Kohler 277233 oil filter is a longer filter use it on my DC mowers as long as there is room for it to fit it will work.
Longer's fine as long as there's room for it and Kohler lists it for that engine. I'm with you on Kohler or WIX. No need to overthink a routine oil change.
WIX aren't the filters that they used to be. The quality has gone downhill fast since Mann+Hummel bought them.
I won't use WIX, Motorcraft, or Purolator oil filters on anything that I own. The black glue that they use can break loose and circulate through your oiling system.
