New to me Briggs 8 hp on a Troy Horse Tiller
andrewslarge
Can anyone help me with a model and type?
There is no plate. At first, I thought it fell off, then I thought it’s stolen, finally I found one for sale and apparently Troy Horse tillers of this era DO NOT have a model/type/date code plate??
I have the horse tiller model but I’m a Briggs guy and would appreciate any assistance?
I’ve worked on probably 400-500 Briggs engines in my life and this is a first for me. Sometimes it’s the wrong recoil cover but never no plate.
Thanks in advance!
Model type code plate is missing. It would of been were that clean rectangle is above the starter.
Here’s a brand new NOS replacement engine for sale now from Troy Bilt. It’s for a Horse Tillers.
The only time I have seen that is when engines were acquired through non official channels. It was done to avoid the engines being traced back to their source which may of been an auction or other unapproved sale.
That’s a possibility. I just got it and was going to look at the parts. No plate?? Found another NOS exactly the same engine….no plate.
I know it was made around 1999-2001 judging by the colors and labels. Just hope someone has a very similar engine with the model/type?
From what I can tell, someone went to the trouble of removing the riveted plate on the starter head. This suggest it was "acquired" by nefarious means in the past. It is a basic 8HP flat head horizontal crankshaft engine design. Possibly mid-late 90's just before B&S switched to the OHV designs.
I thought the same thing until I found a NOS Troy Bilt Horse tiller replacement engine.
No model/type/date code plate on Horse tiller
Is it possible, they did this so an owner would have to buy parts from
Troy Bilt instead of directly from Briggs?
I think your first impulse was correct. It was stolen. The other one, the NOS, who knows. But yours definitely was borne with the plate, as the clean rectangle shows. I suspect the NOS also used to have the plate but someone cleaned the cover so there is no dust outline. There is no good reason to remove the plate. Maybe someone repainted the cover and didn’t want to mask it and then couldn’t find the plate after the paint job was done? Maybe, but more likely it’s an attempt to destroy evidence. I kinda doubt that Troy Bilt was trying to emulate John Deere and sell parts for the Briggs. Deere gets engine manufacturers to put their name on the engines and make changes to things like air filter housings so only Deere has the parts. This is a stock Briggs with no Troy Bilt markings.
Rural King did the same thing. They would sell engines with the code ground off, which resulted in you purchasing a new engine with no warranty.
