Briggs and Stratton Generator gas cap
nbpt100
I am trying to find the model number on a Briggs Generator so I can get a new gas cap. I can find a model number on the engine or for the machine. I can find the serial number with a QR code. Can anyone help me get the model number from the serial number ?
Scan the QR code, it will give model, type and code numbers for your engine.
Appears engine is a 25T235-0110-G1, But being on a generator the fuel tank and cap may not be part of the engine diagrams, and instead will be part of the generator itself.
Generator model number should be a tag on the inside of the generator frame next to the engine.
Can you provide a picture of the generator itself? Is this a B&S storm responder?
Can't you just measure the diameter of the tank opening and get any cap for it? Long as the threads will play ball? Vented would be nice.
Most portable generators use a bayonet s style fuel cap, so measuring and using a generic cay is probably unlikely As stated having the model and serial numbers off the units ID tag is the best way to get a replacement.
Hello N.,
That means we are just guessing?
That picture I posted is not a guess. I am waiting to see if he gets back to me with a picture of the machines model number and or serial number. He said the gas cap has a hose coming out of the top of it. Some kind of a vent.
If the cap has a hose coming out of the top of it, it is likely not original, but a borrowed cap. Many 4-wheeler fuel caps have a vent hose on the top center of them.
I have not seen any Briggs and Stratton generators with a vent tube on the top of the cap.
