- Sep 7, 2024
- 3,447
Hello D.
Have you ever seen how slow SAE 30 pours out when cold? The same thing is happening inside the engine and an additive like Lucas just makes it flow slower the colder it gets. I quit using straight SAE 30 years ago except for gearboxes and older 50's tractor hydraulics.
I also used to use STP oil treatment year-round until I learned more about fluid viscosity and the cold. Great stuff, but it hampers the oil flow.
Try at least a good SAE 10W-30 and no Lucas additive. The additive has permanently penetrated the pores of the metal by now and adding more is just a waste.
My old series 6 Snapper RER has an 8HP engine that is a similar design.
I'm fairly certain that switching the oil will help resolve this issue.
Of course, check your throttle shaft on the carburetor for excess side play on the throttle shaft. I had to replace my carburetor because it wore the housing out at the throttle shaft and would not idle properly, but yours could be hanging slightly and not allowing the throttle plate to initially close like it should.
These old engines are great, but they have their quirks with age.
I think your governor is working, but sluggish. If it did not work the RPM would not come down at all.
