- Sep 7, 2024
- 3,467
Hello S.,
Please provide the Product information label information off of the machine chassis and off of the engine label. There were many of these built and there were changes often made during production.
That faint click you are hearing is the fuel solenoid activating when the key is turned to the on position. That is normal. You are not getting a starter crank signal from the switch when turned to the crank position.
This could be a failed start switch or a safety switch preventing it from cranking.
Make sure that both of the operator directional handles are in the park position, because they each have a safety switch.
