John Deere S100 Wont Start, Details In Post
Senk420
After a 2 week heat spell it was time to mow again, mower was parked in the garage, nothing changed or was done to it as far as I know. However when I went to start it it just "clicked". I thought maybe I had left the key on or it had got turned on by mistake so I put my trickle charger on it, it took a charge and my multimeter showed 13+ after charge. However still no start and still just a click My "instinct" said solenoid so I went ahead and ordered a new one and put it in but its still doing the same thing. The brake switch is new as well so that should be fine and I'm trying it with the emergency brake enabled so the seat switch shouldn't matter but I've tried it sitting there as well. I've engaged and disengaged the blades and cleaned all terminals and ground wires. Still nothing is getting to the starter. Any ideas?
Try this troubleshooting procedure I’ve posted many times.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
The clicking you hear is most likely the carburetor fuel solenoid.
Starter circuit goes thru ignition switch, PTO switch, Brake switch, Reverse Switch, and finally the starter relay [solenoid]. Otherwords make sure the PTO is off, unit not in reverse, and brake pedal fully depressed.
I was finally able to get back out in the garage and tinker a bit, the solenoid seems to be losing power at the small terminal. I'm at 12.5V at the battery and at the large terminal on the solenoid. However when I get to your third step and check the small terminal of my 4 post while turning my ignition I am only getting approximately 6.9V. The ignition is new as is the solenoid. I've examined wires for fraying and loose connections.
You now have a mechanics nightmare. Using the wiring diagram that Star posted and a VOM you have to trace the wires to find a voltage drop. In this situation time and a great amount of patience is you friend.
make sure you monitor battery voltage when you try to start it. You won't be the first person to be fooled by a battery that shows 13V but dies under load.
All 12V electrical systems are prone to bad earth/ground - check that the ignition system is well grounded - nothing loose or corroded.
With all my 12V systems (including my road vehicles) I run additional, to chassis./frame return, dedicated earth/ground wires. I rarely have an electrical problem.
:devilish:
