X140 not charging
CraigH
Hi all, I've got an x140 automatic and the battery isn't charging.
Struggling to find a suitable parts diagram with part codes for the stator and rectifier.
Also, are there any tests I can do to rule either out?
What RPM is it not charging at?
Do you run the mower around the yard at idle speed saving gas?
Not charging at all rpm.
Nope, never run it around at idle, always full throttle when mowing.
Please post all engine numbers and we should be able to find you an individual parts list and possibly a service manual.
According to JD that mower uses the 40N877-0001-B1 which uses the 592829 stator and 794360 regulator with the 5/9 amp regulated system
Make sure you are getting battery voltage to the wire that connects to the tractor harness side of the regulator and make sure the ground wire for the regulator is present and connected. Disconnect the single wire between the stator and the regulator and with the red lead of a meter connected to that lead and the black lead connected to engine ground you should have 28+ v AC for the 5 amp system or 40+ volts AC for the 9 amp system with the engine running full throttle. The amp output is determined by the flywheel magnets.
Before testing, test the battery. 12.75 volts at rest, and also load test it.
Many thanks for the replies everyone, will post engine and mower details later when I get home from work later.
