Kingcat
Hi guys and Girls, I need some help with the wiring of a Troy-Bilt/MTD (I'm in Australia that's why the MTD) Model no 17AF2ACS309 or 17AF2AC5309 Serial no 1 E092HI0229 Zero Turn mower with a 52
" Deck. I need to see how the solenoid is wired up as well as the Negative wiring as the loom I have installed doesn't seem to have it??? (original loom had been cut up so the mower could run without and of the safety switches) If you can help me with pics or a correct wiring diagram that would be fantastic, if you need pics of the mower etc please let me know and I'll get them. TIA
